My 98 300tdi occasionally loses power steering when setting off and this morning there was a whirring noise (which disappeared). Pump or steering box? 60 quid against 250! ps not losing any fluid. thanks in advance.
I'd check the pump drivebelt first of all, then pump. I would have thought that it was a lack fluid pressure causing this, not a box fault.
Is the fluid level correct? Has it ever been allow to drop very low, if so the box may need bleeding (usually there's a bleed nipple on top of steering box).
Generally the Adwest steering box is reliable and the only recurring faults are leaky seals.
Cheers, I will check all those, just plucking up courage (minus 4 add the wind and its not nice to be under a def)
Ok as people have taken the trouble to think about it and reply i will come clean.
After Treewolf's guidance I double checked the level and you guessed it, it was very low.
I thought that if you could see the fluid it was ok but then I saw the dipstick on the cap and topped it up and up and it kept going. So problem solved, i guess the whirring was the pump struggling for oil.
Owning a landy is always an exercise in fluid retention(as indeed is the male body after 45) 2diffs, 2 boxes, Hydraulic tank for the winch, not to mention the engine itself. Thanks for the pointers.
