As it,s been quiet on the firewood sales did a bit of work to the Missus old Landy, the top corners of the bulkhead were rotted out and the paintwork was pants, fitted repair panels to the bulkhead. Here is the before and after:thumbup:
all you need to do now is make it a truck cab and you can carry chip and logs in it ha ha ,looks much better in pic 2
Pic 1 has gorgeous woman in though
HI ELF nice job there mate well done did you fit new bulkhead repair metal thanks jon :thumbup:
yes Jon i fitted corner repair panels, got to take the windscreen out and the airvent flaps off to fit them, but it,s worth it. Got my zetor sorted today took the alternator to bits , found a bad conection inside and a sticky brush, charging problem solved, better than the 175 pounds they wanted for a new alternator!
nice job
Woo whooo, join the club. I spent two hours this afternoon re doing all the spade conector, checking the wires etc. Only to find out by a process of elimination that it was a slighty corroded negative terminal.
Hairy buttocks :lol:
