Rapid Super chain causing kickback in bore cut? Advice needed!
Big T
We had exactly the same problem a couple of days ago with some tough old ash, about 14" DBH and leaning. Halfway up the downs they grow very slow and tough indeed- I've seen them barberchair with less than half an inch of hinge left- just incredible.
Anyway, none of us could get the chain to bore (036 running Stihl SEMI CHISEL on a 15") In the end I have to admit we resorted to the polesaw :thumbup:. Spectacular barberchair running to about 18' up :lol:
I didn't bother trying the 034 running an Oregon setup on 16" as it was full chisel- I wonder if it would have been better anyway?
Depth gauges were on the button BTW.
Edited by doobin
I find semi chisel is rubbish for boring, stick with full chisel, just try a different brand if you can't get on with the one you have.
One tip I have is to apply pressure in the direction of the pulling side of the bar as you bore in, rather than just go straight in.
Semi chisel on a 15" bar was my secret weapon for my cs31 (yonks back) giving me so much control 'but' with practice you will be able to put a 25 " bar through with a full chesil no probs.
Saying that after a few sharpens it's a bit easier.
