Arbcar issue
RobRainford
Upon arriving at the girlfriends about half an hour ago, I turned my car off and took the keys out, and the fans and dash lights remained on for a couple of seconds, then it all went off, but the engine management, battery and handbrake light then came back on dimly, can't understand how this has happened, been out in it today a couple of times and nothing was up.
Can anybody shed any light on it? It's a Citroen c1. The last bit of work done to it was a catalytic converter in November. Never had this issue before!
Cheers
My google searches had pointed to ignition switch.
However, I've been to uni and back today with no issues.
I noticed that the rear screen heater was turned on when this happened. And doesn't do it when it's switched off! I'll have a play and see if that's the case.
Power disconnection wouldn't be an issue if I took the battery out, I've done it before, the car is way too basic for the fancy stuff!
