In the 'old days' Stihl and Husquvarna were reckoned to be the best - which realistically meant they had the best power to weight ratio and squeezed more power per .cc. Jonsered, Sachs Dolmar, Homelite etc were reckoned to be a close second. Probably just as solidly built, just not quite as high performance for the weight/cc. The closest Stihl equivalent of the time would be the 051, which was an aging design by then, so probably get equivalent performance.
Probably struggle to find an official max. length of bar, but I would say you could get away with 32in if you're not cutting hard, dry stuff, drop down to 28in if you are.
Alec
