Fantastic new way to store firewood!
Al Baker
Well you know I have to admit that although I can remember watching my grandad and some of the old boys thatching ricks when we still used binders and threshing mills I had a bit of a problem taking notes:-
I had not actually learned to write at that time:blushing:
So while I think you are right that you will need a sub frame - I will have to hope that there is someone more knowledgeable than me on the subject to offer detailed advice.
Cheers
mac
  • Replies 58
Cheers for the Idea anyway Muldonach, I'm Youtubing it now.....
Ah.....hundreds of hours of it..just as I thought!
Cheers
mac
Edited by Al Baker
Have you got a photo of an empty cage, so we can see how you've done the bottom?
Sorry Steph I don't.
the empty cage just sits on the ground, not fixed.
You just need to put something on the ground to keep your logs off it. Doesn't matter what, bits of ply, a pallet or nothing at all even.
I fill the lower cage with logs first and then wire the upper one together. Pop it on top and fix it to the lower one with short bits of nylon string every 2 ft or so.
Blimey, ok, believe it or not, I was wondering what to do with all the rushes in my garden. seriously, the lawn is being taken over by them. I tried digging them up even wondered about herbicide which I hate.
I guess I'd need to make some kind of underconstruction from switches or something?
Improve the drainage in your lawn or garden, apply a good dose of lime at max 2t/acre, apply a high nitrogen fertiliser in spring / early summer and cut the damn things regularly.
Digging is a waste of time, herbicide is expensive and needs a weed-wiper if you want to target the chemical, neither treats the root cause of the rashes:blushing:
If you are looking for high quality thatch we have a few acres of norfolk reed you could try:thumbup1: - but you will need a good pair of wellies!
