Good work!
I think the reason the horse looks a little odd is the fact that horses noses don't bulge like yours has. They're straight, then curve to the mouth, their nostrils defining the "point of curve" (a highly technical term). I'm not sure if there'll be enough material left if you take the "snub" of the nose for it to look ok, might become a bit too pointy.
I can't be critical as you have made a better job than I could have and congratulate you on you work:001_smile:
But to add the comments by Rover, the neck is at the wrong angle to the head.
I reckon that you could easily fix the problem by reducing the hump behind the ear area. On a positive note, at least you have the material left to be able to do both alterations. Good result.:001_smile:
This may help to show you.
Edited by EddieJ
That has got a ' parrot mouth ' :laugh1:
Arab's have dish faces as do welsh ponies so just a bit of tinkering required :thumbup:
