Whistling flue
My Dad has a stove with a flue liner and cowl. In the wind it whistles and makes a sound like someone blowing on a milk bottle. The sound carries right through the house and keeps him awake at night. The only thing that stops the noise is opening the stove door which you can't do when its lit really.
Has anyone experienced something like this and what did you do to solve it?
simple low cost solution-ear plugs:lol:
There's a leak somewhere in the system where the air is blowing across a resonance tube - just like blowing across a milk bottle.
My first checks would be the flue itself (perhaps the door is sealing so well that a gap is being pulled open in a join later up the gas flowpath?) and the stove door (perhaps there's a gap there?). The door is the easier to check, so perhaps smart to start there?
A few things that might give clues: is it happening immediately on lighting, or does it develop later; does it happen on any stove air vent setting; is it low in the system, or high in the chimney?
Lined flues will carry noise a lot more if they're just hanging free. The noise transmission is reduced a lot if it's insulated with vermiculite, is it?
The other thing is the cowl, or the lack of one.
Change the cowl if you can do so easily for a different type, the ones with a band around them are quite good.
