Polyurethene disaster almost made me cry
Rob D
:crying:
Codensed story. Job to make long bar type shelves that join together. 2.4m long 3" thick and heavy. Resin filled any holes which took ages. Finally finished and one last coat of thick polyurethene on top...
.... and the stuff wouldn't go hard. Could scratch my nails through it after 3 days. I think a combo of thick coat and cold night...
Had to sand all 4 boards down (took twice as long as kept gumming the papers up) and re treat (with a different varnish).
Very painful lesson indeed....
I think it was down to thick coat and low temperature.
What was more gutting was when I got to the 4th board it had hardened a bit more overnight in the kiln.... would they have dried with time?
Dunno.... but a lesson to myself in that I need a proper area to dry things in.
I'll put some pics up when they're (hopefully) all finished!
I have little experience with brushed finishes (I spray) presuming you are doing that? But putting on a thick coat without letting the coats underneath really cure, can turn the whole thing to mush. A bit like when you try and put on another coat of gloss / eggshell before the previous is fully cured.
I use a PU that is touch dry in an hour, no matter how thick I plough the stuff on - but then it is always in the warm.
Morrells 440 is a good acid cat.
