  • Replies 44
Yeah thanks btw! Mostly new krabs, mallion so i can put a pulley on my cambium saver, and the best bit.....new 150' rope
It's ok :-). How will you feed your rope threw your pulley as it will be fixed with a million? I suppose if you don't have a splice it will feed straight threw.
Only spliced one end.i may be able to fit the splice through but if not its a case of threading it on from the unspliced end before the climb, then installing it when I get there like normal. I do climb both ends alternated each day to try and avoid excessive wear one end and milking so shouldn't be too bad to work it out
