At the risk of upsetting someone, if you're taking it to an authorised Stihl service centre look to see if they sell chainsaws as well.:001_rolleyes:
I've got three tools over the last four years "written off due to seized piston" by Stihl centres.:thumbdown:
Don't waste your time or stress, send it to Spudulike. :thumbup1:
Not being funny but we are talking about a MS660 here - cast iron heads were found on 60s-70s kit like big Danarms, Homelites & old McCullochs etc almost all modern saws are Nikasil plated aluminium:confused1:
yeah ive no idea about chainsaw motors in terms of what materials are used - was going by 2 stroke moped motors - some of the air cooled ones still use cast iron heads....
as far as im aware you can heat seize a motor just by not letting it warm up and flogging it regardless of what kind of air/fuel mix its running on? but if it had heat seized it wouldnt be a case of it not being able to start - it would be locked solid and would have stalled prior to that?
Thought so - no worries, learnt many of my skills on Honda fours and mopeds then went on to cars and now saws, still gives me a buzz when you turn a knackered saw in to a runner.
Not really come accross cold saws seizing, they are usually a little boggy when really cold and a few minutes warm up is normal procedure.
Most of the seized saws I have had through have seized then freed up and the normal issues are old or bad fuel, poorly adjusted carbs or air leaks - got to remember that some of these saws are revving at 13k - 14k rpm, a fair bit higher than many of the old two stroker bikes.
Cheers Al - appreciated, not all service agents are bad but know what you mean:001_rolleyes:
