SRT Rescue
DrewB
  • Replies 38
Saw a simple system from Scott Forest when you tie a prussick to your spliced end of your line then the prussick to your hitchclimber leaving the eye free taking up the slack with the prussick side and on your standard climbing hitch e.g VT,Knut etc then when the casualty is reached connect the splice to them and release the prussick which will lift them up hopefully! sorry didnt take any photos Drew. Its pretty simple. Some sort of progress capture set up maybe utilizing a pro traxion would work?
Tie the casualty to yourself however you normally would. Ascender on their line above them with a micro pulley and cord with big splice.tie one end to casualty, splice on your foot, stand up on it to lift them. Sit down (slowly!) to take their weight onto your gear. Then disconnect whatever system they're using. If that makes sense?!i think there is a version like this on the vtio website, though only covers static access lines, not srt as work positioning
Imagine the tachyon is Casuaties line .
Set above climber drop down attach casualty to you and/or new system, use 3:1 advantage to raise casualty.
Just something I chucked together quickly! Hardware could be varied and achieve same result but I don't need to tell you that...
think 3:1 would help with fatties!
