Wanted- a piece of maple
tony-d
I have some sycamore drying but not that wide. Can you join a couple of bits together? Does the sycamore need to be dried or can you use green wood? I'm near Ripley so close to you. If you want to give me a ring tommorrow on 07981 905009 Alex
how do you plan on making the butchers block?
its usually made in blocks end grain facing upwards and braced with a frame to stop spliting if you used it just like a board it would warp and eventuakky split.
Ive only seen sycamore blocks but ive heard older ones were made of beech.
I did a job once for a posh Chinese restaurant and whilst there they asked me if I could level up their chopping block in the kitchen. Did it in situ with a 440, chips everywhere. It was definitely syc or maple of some sort.
Edited by Graham
sp
Maples (sycamore and, I believe, the native field maple) are naturally antiseptic, which would make sense for kitchenware.
Beech is close grained, clean and doesn't taint food so would also be a logical choice.
Agree that it's usually end grain though - that way the knife cuts go down the grain, which closes up. If you cut across the grain on a face it won't do this, and will inevitably bow or crack.
I don't have either in that width I'm afraid.
Alec
Hi Alex
i will call you tomorrow just as soon as i have mot the car. thanks in advance for your help.
tony
Hi forum
i wanted to ask if there was anyone around the guildford area who would have a piece of maple 150cm x 70cm ish
i am wanting to you use it for a butchers block.
Any info would be great.
Someone made us a beautiful table out of burred maple, it was felled in Letchworth, years ago, hope you find some, keep asking...
