hi i have just borught a secound hand ms 200t, gave it a full clean out when got it home but still having trouble with it not puting much power out and it cutting out and before every one say i have cleaned the air fillter and the carb any ideas anyone, any help would be greatfully had
cheers
cheers
Have you put fuel in it sweetheart?!!!
Sorry, couldn't resist...:sneaky2:
alot of 200's have dodgy carbs, if you've got one you might get it fixed on the stihl warranty, regardless of date of purchase but dont quote me.
sounds like a minger once they start cutting out all the time its a £70 new carb and that dont always work.
Never buy old top handels or your getting the worst use out of it. There good for 2 years 3 at most then they become noticably crap.
Hold the saw with one hand and the pull start with the other, release the saw without jerking it. ie drop it slowly.
The saw should hang a bit on the pull start then very slowly drop, it shouldnt drop really quickly indicating there is no compression.
Narr look after them properly and you can easily get 10+ years :001_smile:
Try new fitting new carb diaphragms, clean the carb with carb cleaner, you can get it by the can in automotive stores.
As Mesterh mentioned, check the compression, if that is low you may need new rings.
cheers
Ninety percent of s/hand is crap.Hope it did,nt cost you much.
I just found they never run as good as the first couple of years. After that no matter what you do they never run as good.
Point being i use my 200 the most so i want the best performance only new saws run spot on.
But agree they can last for 10 years but there still not be any where near as good as new.
:sneaky2:
