yes, great saw, 36" no bother
they are a good saw, the only thing they lack is the chainspeed of the 084/088/ms880 range, but they have a huge amount of torque which means they will cut through everything you put infront of them!
parts arent to bad, they are old design from late 1970's ish type era but they still make them (or if they dont they did until recently for overseas markets), the anti vibs can be a bit fierce but thats not generally that bigger issue on an alaskan mill really,
The 070 can still take modern bars and chains (although bars wise really only Stihl, Cannon and GB). Other parts I've heard can be hard to find.
It has a mount more similar to 880 than 660. I think it differs from 880 in that oiler hole is in a different place although I'm not sure on that one....
Hi everyone. I just bought an 070 from eBay, powerhead only, so I am now in the market for a bar and chain for milling. My Alaskan is the 36" model. Does anyone have any suggestions or links to good sites?
I believe these saws can take two different chain pitches, so I will have to check the sprocket when it arrives, can anyone tell me how I can figure out from the sprocket which chain pitch I need? If the sprocket is knackered and needs replacing, what pitch should I go for?
Finally I will soon be selling my 048 which has a nearly new 28" bar and ripping chain as well as an 18" bar and chain. Will the forum allow me to post a link to it?
Thanks for everyone's help so far.
Rob
Parts appear to be reasonably obtainable. A lot are interchangeable with the 090G, some with the 090 and even a reasonable number with the Contra (the naming was originally just a rebranding exercise). It's worth downloading .pdf's of all the above manuals and cross-referencing part numbers. Also worth checking ebay.com (rather than .co.uk) as a couple of the American sellers will happily ship to the UK, but don't list here.
Alec
