Large joins help??
_tc
Hi guys I'm new to woodcraft and after seeing these stools for sale yesterday my wife has asked if I can make one for us. How is the join made? I've seen that joint made on a small scale with a router but these are huge. Many thanks, oh and that stool was £280!!
For speed, a circular saw. Without one, it's easy enough to do this with a mallet and chisel, just takes a little longer - mark out a cardboard template, mark the two straight lines on the top first, line up the template on the ends and start chiselling away - a couple of hours' work that way.
Alec
The gappy joint is probably the result of drying shrinkage. On drying, almost all species shrink mostly in the tangential plane ( i.e. at right angles to the radial plane). The least drying shrinkage occurs longitudinally. If you look at the gappy joint, tangential shrinkage would account for it (rather than inaccurate joinery!)
