yes, you have a freeflow return, count the no. of connectors you have on the back or front, 2 for each spool valve plus a freeflow rtn, if you have a factory 3point linkage fitted you loose the red circuit on the front(switched by the valve on the back for outputs)then up to another 3 depending on spool valves in cab, green, yellow, and blue cicuits plus your return, normally tagged black. your normall pump should give you 45lpm at 230 bar if you need any more info pm me
  • Replies 24
dont mention cherrys to goaty jimbob, its like a swear word :lol:
Its not their fault iseki retail a shaft seal at £39, that costs £6-7 at bearing/seal stockists. MF are £42 for same part.
Fit genuine parts go bankrupt sooner!
thanks for that lads, will have a look see what can do now have some ideas.
you finally get a seal then goaty?
  • 3 weeks later...
think i have found the freeflow return yesterday, if am right it only needs extending by approx a metre it was already there like it was said. thanks :thumbup1:
