I may not help but when I bolted the seat runners from a Galaxy into the back of the Steyr Puch Van (cos I could use the spare seats from our Galaxy) & fitted seat belts too btw.
I showed it to our local DVLA, at Coleraine, the lassie came out to the car park peered in and said, sure its only temporary:confused1::thumbup1:
I was registering the van as private light goods (i think?)
I then turned up for my first MOT, & I was booked into the HGV lane:lol:
cheers
M
It would be worth getting it reclassified due to the tax. If it's a tipper rather than a STD 110 it will be classed as a commercial vehicle so lower road fund licence
Didnt affect mine at all.:confused1:
Yep.
It started out as a 110 hi-cap, now it is a tipper. I think the fact that it is 3050kg gross and a 1995 vehicle meant that the taxation class wasnt changed- still comes as PLG.
If you do decide to reclassify you could be required to provide an engineers report to prove the modification is up to standard.
When I did my 130 I used the existing bed but raised it by 2" to fit the tipping chassis. I spoke to someone at the DVLA and since nothing had changed with regards to position of lights, change in body shape/panels used, number of seats and the unladened weight change was minimal (approx 50kg) they weren't bothered
Don't think you'll need to,does your V5 say 4x4/light utility on the body type and PLG on the taxation class? if so nothing has changed!
When I converted a CSW to a pick up the MOT chap recommended that I inform the DVLA,which I did,they weren't overly interested and just asked for some pictures,Then amended the V5 body type to "Pick up " which was odd because I think all Hi-caps come under the 4x4/light utility body type,unless anyone knows different!
Cheers
Steve
