201t revving but chain not wanting to move?
samthescam
Hey, basically I want to know if any of you guys know of a simple cure for this. When the saw is started, and you hold the throttle down the chain doesn't move for a while, originally this can be up to 5 to10 seconds. Once it's warmed up there is still a lag but it's now just a couple of seconds.
This is a brand new saw, ive checked to see if the sprocket has anything blocking it but it doesn't.
Thanks
  • Replies 63
Thanks
Maybe, and its a big maybe the chain is too tight.
Sounds like an issue with the clutch taking up. Have you taken the sprocket off? If you see signs of oil or 'glazing' on the clutch bearing faces, or of heavy scuffing on the inside of the drum then that could be the cause. If it's oil then a good solvent flush should fix it (assuming it's from assembly, not a leak). Otherwise, pictures needed, or send it back under warranty?
Alec
Mine does the exact same thing sam. Its maybe a tuning issue....i havent taken mine back for a tune up since new but i think it does need a tweak which im hoping fixes this
Fain enough.don't wanna bore you, but do you find it bogs down really easily as well. I was cutting up a pallet for a fire and found it kept getting jammed up.
