I'm thinking about using stillages/wire crates on pallets for log storage and handling but haven't quite figured out whether its going to work for me.
I can see an obvious advantage to logging directly into stillages, moving with a forklift, stacking to season and loading onto a flatbed or trailer for delivery.
However, unless there is a forklift at the customers end then it does leave the problem of how to offload.
I have a couple of customers who are keen to use stillages and are willing to store around 10 cubic metres at a time. With this sort of volume of sale it will be worth taking a tractor with forks to the site but it wouldn't really be economical for smaller batches unless they are very local to my yard.
So, I wonder if anyone has suggestions for off-loading that doesn't involve a pallet grab on a crane or lots of man-handling and tipping with, I guess, inevitable damage to the stiilages.
I currently run a 4x4 Iveco 40.10 with a 12'x6'6" tipping trailer so maybe I should stick to loose loads & bulk bags.
Your ideas are welcomed!
Tom
Interested in buying your wood in Cumbria
Edited by Tom at Heartwood
Your best option is to store in crates as you said, and get yourself a potato box tipper to go on your tractor/loader. Tip tehm into your truk for delivery, You can deliver loose then no need to cart the crates round the county!
I use IBC cages which I fill direct with the log processor. For short deliveries I use pallet forks on the rear of my tractor. For multiple drops 6 at a time I use my 7.5 tonne curtainside truck with tail lift and a hand pallet truck. I can still do loose loads as my forklift has a pallet rotator but I try to avoid as I have destroyed a lot of pallets whilst rotating. Even when the customer requests a bulk bag rather than a container I always put a pallet underneath as it is easier to handle.
