Another busy day - MS200T finished, chain brake assembly overhauled to finish the rebuild.
MS660 - put it back together, pulls 150psi when mildly warm so happy with that, got a muffler mod that should liven it up a little - all good, no fault found on pressure and vac tests, carb good, tank breather good and carb settings as they should be - no idea why it seized but all OK now!
Pictured is the MS180 oiler pinion that was shagged - the arm on the old one revolves around the worm drive very easily - all good now - oil tank flushed out as it was pretty gloopy.
Ported 357XP had a crank seal leak - seal now replaced and perfect!
For some reason it comes out on my saws or when I'm about lol
Seems to:lol: the vacuum and pressure check were perfect, unusual for a 357XP but it is now spot on, just got to put the clutch on and find a bar for it!
From one tool to another...
Sussex Groundie wins the title of "top techie" for today.
It is in fact a Briggs and Stratton tool for levering 1/4" fuel hose from hose tails on tanks, carbs, taps and filters.
So much better than messing around with pliers and flat screwdrivers.
Part number 19600 @ just under £6.00 plus vat, available through any good Briggs dealer.
[ATTACH]126040[/ATTACH]
[ATTACH]126041[/ATTACH]
[ATTACH]126042[/ATTACH]
[ATTACH]126043[/ATTACH]
And you can stir your tea with it:thumbup:
