What's on your bench today?
spudulike
I'm not quite sure how they work, I was thinking perhaps I could just change the timing of the weight swingie thing?
I need it to just bounce, not move. Just holding it in place is not an option.
Why would you not want it to move forwards. Just out of curiosity.??
I want to see if I can use it as a post-driver.
In the Netherlands the post-driver as used most in Britain is not widespread, most contractors use a small crane/mini digger/hiab on Mog with a vibrating block.
The vibrating makes the soil behave more like a liquid, allowing the post to sink in with only a little persuasion.
I want to try to put a swing-lift on a trailer, and adapt a wacker plate to drive posts by making it jump on the spot.
I thought of making up a base for the wacker , with an 8" tube, 2' deep welded underneath to hold the post.
I think it should work, if only I can make one not move forward....
If it does work, I can mount it on a quad-towed trailer and have a very cheap way of getting posts in in places too tight/soft/delicate for a tractor.
Edited by Daniël Bos
Get hold of one and take it apart. See what you have there. Then with a bit of brain power you should figure it out.
I probably will.
But if there's somebody out there that can just tell me "yes, just move the quasar-pulsator 73 degrees towards the shake-generator" or something equally helpful. It'll be less of a gamble, in case it can't be done.
I think the forward movement of a wacker plate is due to the shape of the plate, the actual vibration action of the wacker is a weighted revolution, bit like a crankshaft without the piston and rod
Sent using Arbtalk Mobile App
Is that a supposition or a fact?
If its fact, how come you can reverse travel direction on the plusher models that have the same plate-shape?
I did say think, I have known them to move backwards if you start moving them backwards, I would guess its all down to the rotating weight thing
