Homemade timber trailer
Michael C
  • Replies 25
Nice trailer, how much in materials did it cost?
Didnt actually make it up yet, but the wheels and axle stubs were the dearest of it. The steel wasnt too bad.
Nice trailer
Would it have been 'do-able' to make a rocking beam style axle configuration?
what size is the steel box? 3mm x 100mm x50mm?
Yes, it was an option but I didnt think it was needed for a small trailer, especially when its just for my own use. It would also add more weight, lower the ground clearance and be prone to wear. As it is, it follows the tractor lovely, and I bolted the hitch on so it could be easily adjusted to suit a different tractor etc.
I used 100 x 50 x 5mm. I though the 3mm would be too light, i was going to order 4mm but when I asked, the 5mm was only a few quid dearer.
I also plated the 2 middle crossmembers (and drawbar) with 4 x 1/4 inch flat as they are also the 'axles'
It may sound heavy but its very light, even to move by hand. :thumbup1:
3.2 rods good choice on 5mm steel' i much prefer stick welding to mig welding, harder to do but a better weld i think :thumbup1:
Easy decision for me because I dont own a mig welder! I have an inverter stick welder which is a gift for welding out and about but I think the ancient air cooled one I have gives a slightly better weld.
