ok, not one of my milled pieces, and after seeing that bench by tommy treecarver, i thought I'd never show my work again:001_smile:
Ash butt. 18h x 26w. Bark stayed on thru the drying, and those big splits (and little) are filled with epoxy resin loaded with brass powder. Unfortunately, I'm about as good with a camera as i am a food blender, what looks a dull army green there I promise are lovely streaks of gold. And that ripple in the ash is just beaut.
first sprayed coat of lacquer on, I'll put about 4 on and polish it up to a 1200 semi gloss.
Ive always wanted to make a log side table.
Looks good and I've just got some brass powder to mix in with some resin!
Looks good on your table. :biggrin:
Rob, load as much powder into that resin as you can get - it's heavy and sinks. thick paste. fill any tiny pits with powder and superglue. 360 grit brings it up nice, anything more seems to dull it.
Guys, I use east coast marine supplies, south shields.
brass powder 240 mesh.
2 part clear epoxy laminating resin
Over that - you want a PU lacquer. If you don't have spraying gear, you can buy it in a tin, I think even halfords sell it.
Words of advice though, experiment first!
And definitely experiment with mixing up your epoxy - the measurements have to be bang on, or it will be soft and you'll never rub it down.
Before filling (esp endgrain) - blast a couple of coats of lacquer on first before filling, or you'll have a mess. You can buzz the lacquer off when you're rubbing down the brass..
