It is cross loaded if you choke the lanyard with the crab against your TIP.
No it isn't. It is loaded out of alignment, but that is not the same as cross loading.
  • Replies 38
Unless you were top roping from a high anchor point, then half hitch second.
The hitch would keep the tension on and would be the first to take the load then the chocked crab. This would be good apart from the crab where I would have a chocked sling or use s timber or girth hitch.
