If you already climb on a VT with ddrt what would happen if you stood up using a pantin? Would you not have to push the hitch up? I used a RW this weekend and it is different to my unicender! It will only self tend with a lanyard over the shoulder.
  • Replies 20
No my hitch slides up on it's own
Yeah you do have to push the hitch up, it will not self tend unless you use the lanyard trick or I suppose some kind of chest attachment, hoping to give the RW a decent try out this week on some tallish pines.
I think a lot depends on the harness and bridge you use. As well as the hitch you tie. I have to throw the lanyard over my shoulder with the unicender as well because it is key to eliminating slack as i climb. A hitch with RW is not as efficient as a croll or unicender on ascent but it is mainly designed to make work positioning SRT more accesible. The f8 revolver system is great but it must be removed entirely before ascending directly up the line
not having used one of these yet, im just speculating from what i can see.....but the rope wrench being in the horizontal position seems to be what creates the friction, and also what prevents it from ascending easily hence the need for clipping the lanyard over. but what about if instead of clipping your landyard over, if you clipped the wrench upright against the rope...would this remove the friction element and allow the hitch to smoothly advance as you footlocked?
I just set it up to try out that idea Steve and as the hitch is supposed to work independently of the RW then I suppose it may work but after using the RW on a Oak, dead wood today and just clipping the lanyard over the shoulder I don't think it would be of any advantage?
I never, well hardly ever, climb SRT and only then for access so I had some good fun today.
you have to have to long a tether for this, I tried it tonight ;)
