Hi,
Currently i grease the gearbox of my Stihl long reach hedge trimmer with the small tubes of grease sold by Stihl that screw into the housing.Is there an attachment i could buy that would enable me to use a normal grease gun as the current method is expensive?::001_smile:
Cheers mate.That sounds pretty straight forward.I wondered if there was a grease nipple that could be used rather than unscrewing the bolt off everytime.
nope unforunatly, do you grease the angle box?
It's worth buying the Stihl grease despite the cost. The bigger tube is more cost effective. I have used other types of grease and they just dont seem to "stick" as well.
The Stihl grease is very sticky compared to your bog standard bearing grease so I doubt it will be as effective tbh. Well, you may just have to grease it a lot more than normal I suppose.
BTW, the bits inside the gearbox's arent cheap if they need replacing!!
