As we can see, this depends on specific uses, strategies, styles and strength needed for a particular 'trick'.
So, within a specific range of equipment, should have a range of fitting ropes etc. to task.
In this working environment, durability is high on my list.
Also, hi tensile, low elasticity is not always best. Elasticity can be preloaded with tension, and/or used to dampen impact forces to supports during rigging.
If you have 10k line, and same braid and materials in a 20k line(or as same, 10k line used in pulley on load); you will get more elasticity, at a given loading; from the 10k line. And, if the 10k line is reeved thru a pulley that is on the load, each leg is loaded to the same percentage of tensile strength as 20k line with load on it(without pulley). So, over kill on tensile to load ratio can give less use able line if elasticity is valued in scenario. Then, too can load cheaper lines, and wear them on lighter loading, save more expensive
