Worryingly the blade came loose on my japa 100 today, stripped it down and it looks like the blade has warped, do blades commonly warp after a certain time? this one is the tct blade and its about 3 years old, Thanks.
D.M Firewood,
have had a few logs snatch and get thrown out but on this occasion the nut that holds the blade in place just came undone which was odd as its a left hand thread, ive tried putting the blade back on but just vubrates like hell and doesnt run straight, not sure on size will be having another tinker with it tomoz, thanks...
Thanks, will get the blade looked at but cant understand why it just came undone without prior warning was working spot on until it happened and really sharp?
Will give these a try heard they are good from a previous thread Cutter Servicing in Braintree : Haydens Saws Ltd
hi mate,
they can be very sketchy/snatchy things. sometimes a saw doctor can sort the problem providing the blade is not too warped. new blades are not that dear either if things turn sour and i can pass on manufacturer details for the best price. its worth trying a blade with more teeth as i have which makes the cut smoother and eliminates pretty much any snagging.
hope this helps
andrew
hi mate,
hope this helps
andrew
Thanks Andrew, i will get back to you if i have no success with Haydens, Cheers!
