  • Replies 23
Timberwolf s have a emergency shut down if they overheat. Sounds like you may have a engine problem just like i did back in Jan. The coolant s used had been of a different type mixed and made a sludge blocking the cooling pipes on the main block. It cost me a new engine so if i where you I would check it out. Kubota engines are not cheap.
this might seem a little too obvious but its worth checking your inline fuel filter to see if its filled up with rubbish and replace it if it is. even just taking it off and flushing it through as much as possible seems to do the business. good luck with it
Its electrical lorry give the switch a good dowsing with wd40,weve got one that does exactly the same,sometimes after only 5 mins or so,weve changed the filters on ours and its been recently serviced,but the issues with ours seem to point to the switch,good luck.
