  • Replies 54
Maybe as govt begins to implement change to support urban forestry, the laws and get outs adopted by some people will be removed from the system, and builders will have to up there compliance more so, 'should it be the case that they do not at present'
If a property is underpinned correctly then the tree need not be removed, Im lead to beleive. so there shouldnt be the need for repeat pruning, if the tree is found to be non-contributory to the initial subsidence, i guess it all enables the practising con to have more tools at their disposal. sectorThis is in relation to the whole it could be the tree mentality that may be prevalent in that
so where does this stand when it comes to use on trees within proximity to powerlines ? surely they will require regular pruning regardles ? . my interest is purely aimed at understanding how this system is intended to be used .
Soory this was a derail and was in relation to subsidence not power lines.
But the reason they are doing it is to try and combat the new requirements by some power companies to not cut trees soo heavily, but at the same time keep costs down,and maintain theclearance. I cant remember which way round it was, whether the power co.s wanted more or less off, and something about application to control re-growth, to reduce the tendency for cutters to keep returning annually if less is taken off.
