Daedalea quercina here on an oak stump, but not on the felled trunk which has Laetiporus fruiting.
makes me think the Daedalea has invaded after the fell, with the Laeti keeping it out of the trunk.
  • 3 weeks later...
  • 2 months later...
  • 11 months later...
  • 8 months later...
Ganoderma resinaceum here on oak with what appears to be Inonotus cuticularis (the clustered bracket) below it.
Alinicoll with the steer toward I. cuticularis.
I. cuticularis is more usually found associating with beech.
There are a only a handful of records of it in the Uk on oak, so fairly uncommon.
ImageUploadedByArbtalk1469561522.440421.jpg.137fd2bac25ef8064f5d873efe732515.jpg.
Ganoderma resinaceum here on oak with what appears to be Inonotus cuticularis (the clustered bracket) below it.......
Intrigued by the close proximity and seemingly rare association we took a slice through the oak to look at the two decays.
You can see from the still attached (but sliced) cuticularis brackets, that the I. c decay is significantly different to the rest of the cross section which affected by the decay of the Ganoderma which is noted as colonising via selective delignification.
The border of the cuticularis decay has been enclosed by a thin dark psuedosclerotial plate which is keeping the resinaceum decay from breaching its own section of the wood volume.
