also if in a CA or TPO the LA might do something
There is nothing that can be done. Knowing how the tree dies is useful information but it alone is not going to get a prosecution criminal or under the TCPA.
You need to catch the culprit in the act or get a confession. It’s not about what you know it’s about what you can prove in a court of law
  • Replies 22
From that listing: It needs to oxidize, to solubilize (I thought the term was dissolve?)
and further on, after it's told you to hammer as much nails in the tree as you can, it goes on to say:
Cover nail heads with mud, if necessary. The purpose of covering copper nails with mud is to conceal the nails. Copper has a tendency to show quite plainly in the trunk of trees due to its bright coloring. Covering the nails makes the process less obvious with a casual glance and can preserve the look of a yard as the tree starts to die. Using mud to cover them, though, will not completely hide the fact that something has been done to the tree.
wich to me is clearly aimed at those with less than honourable intentions?
