Chestnuts are not worth the effort,elm is but can be hard to split,as can eucalyptus if you dont split it soon after cutting it up,theres a start,but most of it will burn ok if well seasoned,if you get any ash,dont bother with it..just let me know & I will come and relieve you of it!:sneaky2::biggrin:
Aye, I've got plenty of Elm. As you say, it's a bugger to split but it does burn well. It's been standing dead for some years so it's well seasoned and as such it burns hot and quickly despite what the old poem says.
Got some Beech, which splits beautifully but I haven't burnt any yet.
Got a bit of Ash too, but I think I'll hang on to that if it's alright with you. :001_tt2:
I have struggled to split some Elm thats trunk was very thick and bendy, which meant the grain was all over the place. Had to cut it thin to split otherwise it laughed at my 10 ton splitter.
Lime was also quite time consuming to split even though it was so easy to cross cut as it is so stringy.
In my opinion once dry there is no wood thats not worth burning.
A little poem to help you,
Beech Wood fires burn bright and clear
if the logs are kept for a year
Store your logs for Christmastide
with new cut Holly laid beside
Chestnuts only good they say
if for years its stored away
Birch and Fir will burn too fast
blaze too bright and do not last
Flames from Larch will shoot up high
dangerously the sparks will fly
But Ash Wood green and Ash Wood brown
are fit for a queen with a golden crown
Oak Wood logs if dry and old
keep away the winters cold
Poplar gives a bitter smoke
fills your eyes and makes you choke
Elm Wood burns like churchyard mould
even the very flames are cold
Hawthorn bakes the sweetest bread
do it is in Ireland said
Apple Wood would sent the room
Pear Wood smells like flowers in bloom
But Ash Wood wet and Ashe Wood dry
a King may warm his slippers dry
Hope this helps :001_smile:
Thanks. I know the poem (I referred to it in an earlier post) and people seem to have varying opinions on it.
It doesn't offer much in the way of information on splitting though! :D
No, no, no, no, no - This is what we have to contend with; I'm sure other's will agree :biggrin:
That poem makes nonsense of reality.
Ultimately, any wood if properly stored and seasoned will burn.
