  • Replies 23
It would seem its like the reverse on when putting a cambium saver up with a throw line check out treeclimbers companion if you have one and then just reverse the procedure if your unfamiliar with it
my copy of tree climbers companion got flinched years ago.... but i recall and quite afternoon spent learning how to set up a cambium save from the ground, will have to give it a shot.
just found this vid, nice refresher on the setting up and although the voice is quite, the retreival is easy enough to understand
[ame=http://www.youtube.com/watch?v=vllcoFNdOlg&NR=1]YouTube - ‪Installing a ring to ring cambium saver from the ground‬‏[/ame]
