Sheet bend
Steve Bullman
  • 1 month later...
If joining two ropes of very different sizes, it can slip but if you go through a couple of times (or more) with the smaller rope it will hold alot better. Can't remember but I'm sure I have seen this difference in use or in an old 'salty' book.
Sheet bend is good for joining ropes (same or different diameters) in situations where the tension goes on and off the rope as it doesn't work loose (unlike a reef knot).
A sheet bend is preferable to a reef knot in all situations other than a guaranteed tensile load, with similar diameter ropes, where rapid release is desirable.
Alec
