chainsaw porting
Samuel
Hello everyone
i recently have sent my stihl ms460 to petemate390xp where it was turned from an great saw, into an amazing saw,:thumbup:
if anyone is considering having a saw "ported" i would strongly recommend it,it has loads of power and is able to run upto a 28" bar so would be great for use in a tree at the end of a day when fatigue becomes a factor, i am seriously considering getting my other saws done, due to how impressive my 460 is:biggrin:
I can highly recommend Pete for the modifications, pete communications through out the process was great, and always more than happy to answer any question i had about the process
i can not say how happy i am with it.:thumbup: thankyou pete
Hi just wondered if the power increase would shorten the saws overall life span ? ,also do your measure the power output before and after the tuning ? If so what was the increase , thanks , I have considered getting a saw ported any advise & info app
use a good quality 2 stroke oil & keep the revs low as possible until it has warmed up, over-revving a cold engine is the worst thing you can do....
a ported engine will be reliable if you look after it.
it totally depends o how much power you want out of the saw, i went for a modification where the life span of the engine stayed the same, but the power was increased. It totally depends on what you want from the saw, just send pete a quick pm and he will talk all about it to you:thumbup:
  • 4 weeks later...
bump :biggrin:, had my little 346xp ported my petemate390xp also and it is amazing, it was awsome before i got it modified, but now it is incredible, well worth having it done:thumbup1:
once again pete thanks for doing:thumbup:
I am planning a little dalliance with a 346XP very soon, just done the muffler mod, have gathered some useful information about exhaust/inlet ports, piston modification, transfer ports and squish heights so will do a posting with a blow by blow account very soon.:thumbup:
It will make a change from fixing saws and will be a nice useful addition to the stable but may clash with my modded 345!
