  • Replies 23
Funnily enough Mark I'm on XTC Fire 13mm and am about to change to Imori. I use Armor Prus 8mm (bit of a CE issue but it is available), and it works well on both, and lasts ages.
See you at the next meet!
i actually recently changed from 13mm yale xtc to imori and can't recommend it enough!
imori is alot softer than xtc, which i prefer.
that settles it then, another order to mr jones it is then, cheers boys
Mark,
where are you starting work? for yourself or on the books.
Good luck either way.
luckily on the books mate, company called landscape services based in kent they only have a small arb team so im hoping to learn loads. cheers rich
Are you going to be working with Ian Lee mate?
