Well its arrived. Just been fettling the wiring of the speed indicator (yay it had one).
It has the the makers name as GENETRACT.
Its def single phase.
Now do I make a frame for it to go on the 3 point link or bolt it down?
Bolting it down would have to be to some tree trunks made into large sleepers so still moveable but not as easy as a frame.
I am guessing that at full output we are talking some serious power.
Would a normal shaft be ok or will it need a shear bolt or clutch one
  twistedhicap said:
ill get some of ours at work we built a frame for it usefull can forklift it and use 3pt link too :)
Cheers, all ideas welcome.
  • 1 year later...
hi your pto generator is made by ring rose looking at pic its either 15kva or 20kva it has a durilite 3 light system for the correct voltage for the generator,and there will also be a plug for anti-condension heaters,these were mainly use as a stand by for dairy farms,these generators were made by markon/stanford type lc32 hope this helps regards kevin
Read more
