I will make a couple if I can't find any. The metal tips would be the awkward bit to fabricate
I think if you used Strong timber and just cut a nice radius on one end, then fix a strip of steel round the radius that is wider than the wood, so that the edge of the steel thats sticking up from the board will bite in and hold it in place.
i think you may find some pictures of the metal bit in Gerry Beraneks, fundamentals of general tree work book
jamie
On steep ground and big trees i have put the gob in off my harness and spikes, then started at 1 side with the bore cut. Come back onto the ground and finished off the cut. Working on a spring board would be really tricky i reckon pete, I have worked round this sometimes by using the 088 with 36" bar, even if the tree is much smaller, it means you can get to the bit you need wings for. Good luck and keep us posted with pics
