RopeGuide for Lowering Block?
MOG
  • Replies 23
The pulley will be taking twice the load. E.g 100kg load = 200kg at pulley.
The anchor point will be taking twice the load of the pulley . 400kg
Ah, ok, I'm with you now. Sorry Craig! Doubling th eload at the pulley is not really a problem when you tie it off round a stem but havign a line over a branch stem means twice the load at that point PLUS the same load holding the pulley in place so thats 4 times the actual bit being lowered. Got it!
Hey, yeah i dont climb on it after haha not that dumb mate. i made a purpose one up for rigging like a heavy duty one with the Pinto Rig pulley. But yeah i never install one from the ground due to 4x4 factor. that is a heap of force say branch is 100kg = 400kg max. if you change angles and add friction over branches it changes the 100% of force/times load on the rope.
Also works very well for re-dircets for lowering branch so thay dont swing as far and u can fully lock it off on stem, if no crotch.
MOG
i always use re directs in my lowering to share stress on gear and tree plus it helps with controlled swings.
If i had a spare cocoon/pinto would def use as a lowering device on ropeguide for smaller stuff but my ISC does the trick i just cant install it from the ground.
