forestry trailer
gemtrees
A few pic's of the forwarder. The grab is off at the moment because we have been using it on something else. It all works. If you are interested I will take some more pics with the grab attached and being used. The blue lorry strap is simply there to keep the valve block and pipes together while we moved it from the yard to the wood.
Price is £3,000. + VAT.
That about a 6 tonne trailer with about a tonne lift on the crane?
I have a 3 way tipping muller with an Altas 80.1 mounted on the drawbar.
8 tonne metre 2 Hydraulic extensions. King Pin Seat. Pipped for Grapple and rotator.
It's 16 tonne on super singles. 55 mph. Air Brakes. Adjustable drawbar height.
It's the right height for the Rockinger Hitch, but you could weld on a hitch below for a pick up hitch. The outriggers act as landing legs, so when your hitching up, you adjust the outriggers depending on the load in the mog.
I'm using it with the mog hydraulics, but it has a tank and and I have a speed up box for the rear PTO, but it needs a pump for that.
I've used it for forestry forwarding, but only when ground conditions are relatively good. Great in fields etc.
If you want I can send you pictures.
Ta.
could you send me pics too ?
