ms200t excessive oiling
TreeTomass
I'm not sure how the oil pump works on a MS200, if it pumps only when chain is turning maybe it's because you've been doing heavier work recentely? If the saw is doing a lot of idling it won't use so much oil as chain isn't running so much.
just a thought!
just a thought!
Had the saw for a while now, maybe 2 years, always used about half a tank of oil, no matter what the work is. It's not a major problem, just thought might be a common problem or something?
There's a screw underneath the saw (turn it upside down) that you can turn to turn the oiling amount down.
But a tank of oil to a tank of fuel is about right when the oil is turned to max... surely not that expensive on a 200t though! :confused1:
