Guys
I have 14 stumps to come out between 30 and 40 inches. I'd like to know if i can hire a bit of a bad boy for this job ie carlton 4012 minimum sort of size, bigger if possible (even a tractor at a push). I need to know what, if anything I can get my hands on before i put the price in. Also would £2.50 and inch be too much for this many stumps? Have done plenty of grinding in the past but this is the first serious job i have quoted myself. If anybody can help in anyway then that would be most apprieciated.
  • Replies 22
Ok. Good advice, i can see your point with the inch thing. On that basis then is there a more accurate way to price the stumps without bringing too much guess work into it. Obviously fuel and teeth have to be taken into consideration anyway. So far I have measured all the stumps, adding up the total in inches and going by £2.50 per inch. Should i be allowing more or reducing price due to the number there are. I do want to get the job however imo there is a lot of work there so dont want to get my fingers burnt.
A big grinder with operator should be around the £300 per day mark imo, after all it only costs £250 for a new JCB with driver for a day around here, the days of big money for stump grinding are long gone.
