Hi,
I am just starting up with logs from my woodland.
I have a large shed so plenty of space to store logs inside for the summer. However several of the posts mention getting wind and sun on the logs to dry them out quicker. Should I be storing them in the shed or outside in open crates ?
Lesley
Since you mention force drying in a polytunnel, we do have a quite large glass house... could store them in there for a few months. Would that be better than outside ?
Lesley
I'm sure the answer is in airflow not just an enclosed building.
Somewhere with a roof on and open sides would tick all the boxes.
Putting them in a glasshouse would depend on how easy you could get them in and out and whether the work is worth it
1) Keep them off the damp ground. Ideally stack them on old pallets.
2) Plenty of air movement through them -- (which is not possible in a closed shed unless the shed walls have gaps in them).
3) Keep the rain and snow off them with an overhanging cover.
Anywhere that meets these criteria will be fine. They probably won't start to dry much until the spring/summer, because the air is damp.
Best wishes,
John Russell
Best wishes,
John Russell
Couldn't have put it better myself :thumbup1:
