This may sound like a stupid question but anyway:blushing:, do any of you know how to move dumpy bags of logs around with out a fork lift?? Or have any of you cleaver clogs made some sort of contraption to move them around?
Thanks Chris :thumbup:
  • Replies 23
put them on pallets and use a pump truck or put them on sheets of plyboard and drag them don't know about lifting them though
we use a crane that we built to fit on the three point linkage of a tractor- pretty much the same as an engine hoist only with a three point mounting instead of the legs. Not much use if you dont have a tractor however.
its not the best, but it was cheap, search fleabay for lucas crane!! an you can only deliver one at a time!!! i use a pallet pump truck in the yard, needs concrete/smooth floor thou!!!
I was thinking of converting one of our Transit tipper to a mini-skip loader to load and unload 1m3 bags of logs. Truck could carry two and unload one at a time.
(can anyone make this youtube video work?)
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/watch?v=A6SD38dlnKA?fs=1&hl=nb_NO"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/watch?v=A6SD38dlnKA?fs=1&hl=nb_NO" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Edited by Arran Woodfuels
