Just saw a TV advert for this thing and wondered if anybody had actually tried it. I don't know much about it myself except that it seems to be a on bar chain sharpening machine. Any thoughts?
we bought two for our little electric saws, as they were always cutting in dirty conditions the normal chains would be blunt fairly quick, got two of these, after a month of using them and giving them a lot of abuse, i rate them very well and would recommend them for small saws.
Cheers for the links and the thoughts guys. The pumice here can be pretty hard on a chain, especially when cutting stuff on the side of a road where the pumice has been thrown up by cars and is embedded in trees. A mate of mine uses an electric type sharpener which hardens the chain but you can't sharpen it with a normal file and the sharpener really isn't portable so wondered how these would go. Sounds like they're not much cop for a bigger saw which is primarily what I'd use it for. It sounds like a lazy way out but believe me, working on the side of some of these unsealed roads here, especially around the central plateau area, you can be touching up a saw every half hour sometimes. Dead Gum is also pretty hard on the chain and there's more than enough of those to go about.
