So iv had an idea and was wondering if any one has done this and does it work. Was thinking of fitting a swing lift crane on to my trailer? The idea is for lifting ton bags of logs and lumps of timber.
i've mounted a two tonne engine hoist on the front of my sankey works ok for bags
i've even lifted a petters ph2 engine onto the trailer which is the heaviest i'd lift with it
I fitted a Lucas 250kg swing lift to my Transit. It's demountable so I can get more payload on when I'm not using it for logging. It lifts full bags okay but if I were to fit one to a trailer I'd go for the 500kg version which is not demountable. Make sure you mount it high enough, the one on my Transit could have done with being a few inches higher cos the bags drag a bit on the bed.
  R A HACKETT said:
got one 250kg on a purpose built trailer will hold two bags and is for sale
is powered by an internal battery that lasts for ages
approx 7 x 4 size and has detachable sides and support legs
Got any pics and a price Mr. Hackett ?
Spookily enough I've just fitted a 500kg swinglift to the rear corner of an Ifor. I'll get some photos sorted out when I run through the yard in a couple of days....
  • 1 year later...
Need to be careful about weights and overloading. Vosa are pulling a lot of small trailers now, I got pulled off the M6 !.
One of my competitors has one on a Transit, manually operated, lifts 800x800 bags ok or so the operator says. He built a cross from steel to connect the loops to a central lifting point.
A
Read more
