Sachs Dolmar 112
doubletap
These have points ignition which needs a special tool to make setting easier. The points setting is fairly critical for best performance. The carb settings are also tricky to get right, but when these are on song they are a cracking saw. My mate's first saw was a 112 and it
did a huge amount of work with very few problems. I may be able to source a manual and some other bits . Will pm you if I find anything.
I have a manual for the 113 and 116.
The 113 has the same stroke, bore and displacement as the 112.
Basic settings are (H)=1 turn and (L)=1.1/2 turns for the 113 and 116
I hope this helps - Chris
Hi Chris, yeah that is a great help, I'm on the case and wil let you know how I get on later.
Cheers
Spud
