  • Replies 34
I wonder if it's suffering from the same problem as older Transits- an air leak in the fuel return pipes allows diesel to drop away from the injectors. Have you got solid metal or flexible pipes running the excess diesel away from the injectors? Flexi pipe and clips can loosen and allow a little air into the system....
cheers Will, i will get my guy onto it for a good once over again with all these suggestions, it hasnt been bad of late tbh since the cold weather, it is certainly better with a full tank of fuel
